hoss hogg
I have a 03 2500 4x4 5.7 hemi. I had the engine rebuilt, Texas Speed stage 2 cam, s&b closed dry cai, headers cat delete flow master dumped after cab, deleted the fan clutch. I had a tuner come to my house to put a tune in it. Found out he can't connect directly to the ecu so with his recommendation I bought a diablosport trinity and a reschedule. After 3 hours of fighting i have a truck that may or may die everytime I have to stop. His next recommendations was to get an 05 ecu and a bigger throttle body. I bought an 05 ecu gave them the vin from my 03 to load in the ecu and paid extra to remove any security dodge my have on it i also bought a 90mm BBK throttle body. After swapping the ecu and throttle body the throttle postion is opened 100%. I found the thread about the ecu swap instructions. Before I saw the ecu swap thread I was just going to use my 04 wiring harness straight up as my 05 wiring harness looked identical and the 04 is a parts truck. Looks like that won't work the way I was wanting too. My questions are 1 is the ecu wiring different to the throttle body as well? 2 if I do this harness mod it should let tune the throttle body or do you think I got a DOA throttle body?
