As indicated, I have a 2003 2WD Ram 1500 (Hemi) with 150,000 miles. Engine has a serious miss almost causing it to stall when going uphill. However, once operating temp is reached missfire generally goes away and truck runs fine. I'm probably due for some new plugs and wires. I'm concerned my fuel pump may be acting up. Research shows fuel filter is part of the fuel pump and tank must be dropped to replace pump. Any ideas if those symptoms are consistent with fuel pump issues? That's a really expensive fix replacing the fuel pump on such an old truck.
