06' 1500, 4.7 RPM Gauge *Need Help*
PerfectPotato
Ohio
Just picked up an 06' 1500 with the 4.7.
Had to replace a few things on it and did a fluid flush, but I'm getting a weird guage problem. I've looked online and can't find anything about this. Either the guage works right, or it doesn't work at all and needs soldered. This one doesn't know what it's doing. I did the cluster reset and that did nothing.
No codes are popping up. Friend recommended to change the cluster, but Im afraid that won't be the issue. Any ideas of a problem that would be causing this? Video link*
https://youtu.be/8Qv2zYjxKbY
Replaced:
MAP sensor, Air filter, All spark plugs, idle air control valve, right camshaft, (1) rocker arm, (2) ignition coils, radiator cap, thermostat
Kamikowski
