07 3500 5.9L Hazard lights not flashing
ridenby
Kentucky
5.9L
Have pulled plastic of dash and looked for flasher relays. Found none. Turn signals operate. The hazards do not. What the heck. Help , please.
tron67j
Maryland
Your emergency flasher relay is in the TIPM (fuse box) under hood.
tron67j
Maryland
Not necessarily, you need to do some diagnostic work. It could be just a bad relay in there.
ridenby
ridenby
Kentucky
5.9L
Follow up on this. Went through fuse box under hood and replaced all fuses. One to cigar lighter and another I do not recall were blown. Still no flashers. Ran across utube concerning flashers, said the multi-function switch can cause this. Cheaper , easier than replacing TIPM as the flasher relays are integrated into TIPM. Replaced with the lowest cost switch I found. It works as it should.
