08 to 06 hemi swap
james ayers
everything on these engines seemed the same except the wiring harness i swapped engines and now it wont start
Stangshcky12
Oshkosh, WI
5.9 Cummins
Hope you checked into emissions laws in your state
Most states only allow you to swap to an engine that is of the same year or newer
RonJon '06
Southern Minnesota
If the harnesses are different then one might have MDS and not the other. The 8th character in the VIN should be either a "2" or a "D" and if they don't match then that might be your problem.
J
james ayers
the 06 is the first year the mds came out
RonJon '06
Southern Minnesota
In the 1500 Ram pick-up yes. What kind of truck is your '06 1500 or 2500 and what did the motor come out of? Some pics might help too.
J
james ayers
motor came from 08 1500 going in 06 1500
J
james ayers
it is the exact same except i think like two sensoers were different
J
james ayers
at least the salvage yard said it came from a 1500
RonJon '06
Southern Minnesota
I was considering this swap myself and was told that the fuel rails were different from the '06 to '08. I would double check the VIN numbers if you can, also tell us if there is fuel pressure at the fuel rail and if there are any codes. I'm not familiar with the different wiring harnesses but maybe somebody else can help you with that.
J
james ayers
i do remember one of the body grounds came off but my brother is the mechanic and he said i didnt need it because i already had one so i wonder if i need that ground i just want my hemi back lol i can do anything but wiring all mechanicals are ready to go
J
james ayers
there is fuel pressure i believe this has something to do with the wiring
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I would fix that ground and check of the others. Will the truck turn over or nothing at all? The more we know its trying to do when the key is cycled lets us know where we are starting from.
J
james ayers
it does nothing light come on inside but even when i jump the starter motor wont start
J
james ayers
all dash lights come on but no click and wont run when i jump starter
J
james ayers
its like something is stopping the power from reaching switch side of starter and no power to either injectors or coil packs
KAKA
