1" Spacers for 2WD 1500?
RAM_Designs
Rockwall, TX
6.4L Hemi
Hey guy, first thread I've started here. I've been wanting to lift the front end just a smidge...so I can fit some slightly larger tires and keep that plastic under-bumper aerodynamic thingy from scraping the top of the curbs around here. I seem to just barely touch the curbs with the stock 265/70/17 tires.
So basically, are there any 1" spacer kits? I've done some searching and can't seem to find what I'm looking for...I feel like a 2-2.5" lift in the front would be too much for what I'm looking for.
RAM_Designs
RAM_Designs
Rockwall, TX
6.4L Hemi
Think I found what I'm looking for here: 1994-2015 Dodge Ram 1500 (2WD) - FRONT 1 1/2 Coil Spring Spacer Kit [KC09103BK] | $44.96 | SD Truck Springs | Leaf Springs, Helper Springs and Suspension Parts
Has anyone tried these before? I have 3" of rake from rear to front as it is, so with a 1.5" front lift I'll still have a solid rake there...don't want it to look level at all, just want a little more clearance for my front shroud and maybe larger tires in the future. I assume there'd be no real reason to upgrade the UCA with just 1.5" of lift.
RamminJammin
I have 2" spacers from fatbobsgarage and my rake is almost spot on.
RAM_Designs
RAM_Designs
Rockwall, TX
6.4L Hemi
I think I'll be opting for the 1" Daystar...really like to have a noticeable rake when I upgrade to larger tires, and I just need a minor lift to avoid the shroud hitting these curbs. Maybe later on I'll do a real 4.5" spindle with 3" rear lift and put some 35's on it. Until then, I think I'll just do the 1" front spacer with 33's. Thanks for your input.
68Cudaconvert
