12 ram won't start
ramostc67
12 ram cranks over good but won't start
Abs and e brake light on
Brake light switch come apart pushed back together seen a spark ??
preachp
The Con State (CT)
Hi Op,
Cjeck the fuses first. I hope you took that broken switch out and replaced it. If you did not pop a fuse you may have hurt the Canbus or power control module. If it's not a fuse get a code reader and see if you are throwing any OBD codes.
Good luck hope you get it sorted and welcome,
preachp
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
Well if it is turning over, then the start circuit is fine, it is the ignition circuit you have issue with and that would take some diagnotics troubleshooting to find.
Could be a PCM, Crankshaft position sensor, Camshaft position sensor or associated wiring. A tech is going to need to see what is work to figure out what is not working to narrow it down.
R
ramostc67
Found it. I was a 10 amp fuse under hood
R
ramostc67
Thanks tho
noraa73
