120v outlet
Timsdually
Jersey
Cummins
Am I blind or did they take out the 120v outlet from the interior on Laramie trim.
My '17 had it, but I don't see it on my '20.
Pudge
Alberta, Canada
2021 Power Wagon 75th
up top on the dash in the little cubby hole.
Farmer Fran
Earth
2025 Limited Longhorn
SST H.O.
The "household" outlet in the Limited is in the center console, at the very bottom right under the cell phone holder.
T
Timsdually
Jersey
Cummins
Yup, found it today. had my sunglass case down there blocking it from view. Really is hard to see unless you are parked in the bright sun.
Now to figure the auto cellphone charger. I never get a blue light.
Farmer Fran
Earth
SST H.O.
My suggestion... remove any cases from the phone and find the spot. Leave about a 1/4 gap to the right of the phone to the blue light.
1/4 gap between the blue light and the phone. Once you see it charging put on the case and see if it still works. The case I had would not work with the charger.
Also the truck has to be on.
T
Timsdually
Jersey
Cummins
When in doubt, read the manual.....
It seems the phone has to be "Qi" enabled. Manual says you can buy some kind of cover that makes a non-Qi phone into a Qi phone.
Guarantee my phone is non- Qi.
Farmer Fran
Earth
SST H.O.
Yeah, that would matter :)
ToyHaulin
Ocean, NJ
5.7L v8 Hemi® MDS VVT
How can the inverter 120v outlet be added to vehicles that don't have it?
Ricks Ram
If you're referring to the outlet on the right side of the center stack you would need to install the inverter and seat harness on the bottom of the passenger side seat. You would then need to add the wiring from the seat to the truck. @M2mods who is in the vendor section of the forum makes this harness. Your truck will have the connector for the 120v outlet in the dash but the wiring terminates in the passenger side kick panel. It's usually easier to hook up the 120v dash outlet for people who upgrade their seats because the inverter and all the wiring is already connected to the bottom of the passenger seat but it can be done either way. You can run the inverter trigger wire to an ignition on 12v power source like the 12v power outlet or you can connect it to the BCM and then enable the inverter codes with the Alfa Tool. It will work identical either way and it's much easier to just wire it to and ignition on run power source.
Sent from my SM-G981U1 using Tapatalk
