'13 PCM harness issue
Saltillo Express
Does anyone know if the wiring harness fastener where it attached to the PCM can be serviced or repaired? When I unhooked mine on the left side, it cracked and pieces of plastic fell out. Now it won't latch. Orlando Dodge is trying to get out of warranty (<10K miles) because they are trying to say I was modifying it. Which I wasn't. Bone stock.
Anybody? Anything? They're trying to bang me on a full harness replacement.
jeepguy_1980
5.7L
Can you post a picture?
Sent from my SCH-I545 using Tapatalk
Saltillo Express
Saltillo Express
sorry no it's at O. Dodge. It's the left latching fastener where the harness fastens to the PCM. It was stiff when I unlatched it and it cracked. The PCM and wire connections are good, it's the latching mechanism that is broken.
jeepguy_1980
5.7L
The dealership is right. You really had no business disconnecting the harness, regardless of intentions.
Usually you can get connector repair kits from the dealer. Should be about $30.
Saltillo Express
Saltillo Express
I've disconnected the PCM 100 times on 20 different trucks. Never had one break in my hand. It was defective, in a bind from the factory.
gville35
