13 Ram 1500 - No horn, windshield wipers, flashers or turn signals!
bigalsd
Hello all! I am having an issue with my 2013 Ram 1500. I don’t drive her a whole lot, so I let the battery drain on her a few months back. I needed to drive her to the dump after completing some yard work, so I hooked her up to the battery charger overnight on a slow charge. I went out the next day and she started right up. The issue that I am having is that now I can’t get the turn signals, horn, flashers or windshield wipers to work at all. Nothing on either tree nor the horn will operate. I check the fuses and all look fine. Do you have any recommendations?
smithwessn
Did you check the fuses inside the cab and under the hood? With all of those things going out all at once, I would suspect fuse issues, a poor ground, or poor contact at a common connector.
If it sits for long periods of time, maybe critters decided to call it home and have been chewing on wiring.
