Brucey
I have a 14 ram 1500 with the 5.7 hemI I bought a superchip f5. I plugged it into my obd it memorized my truck then said needed update, So I updated it with the update agent from super chips then plugged it back in and went to change my tire size then throw the eco run on and it went through the updating process then programming got to the end and starting clearing codes then it said programming error and went into recovery mode. I thought it was weird so I hit ok and it started the process again I hooked up my Snap-on battery pack and set it to 13.2 volts so there was no way power loss could have been an issue and I shut all windows doors and turned off radio then tried again yet it still failed and at this point my truck wouldn’t start or do anything so I called superchip support he made me run it through again and nothing obviously then asked if I’d shop my pcm out to them and they ship it back. I said screw that and unplugged my battery terminals held them together thinking it would reset but it didn’t I ended up having to call a buddy with a Chrysler scanner to reflash my pcm.. anyone else have an issue like this and find a fix? The company I bought it from won’t take it back so I’m really not trying to waste this money. Thank you sorry if this post doesn’t belong I couldn’t find any others that were close to this
