18k lb towing, manual or auto tranny?
mhays
Hello All,
I have been struggling with a Ford 6.0 for many years and am very close to buying a Ram. It is not my daily driver, mostly used for hauling a heavy camper (4,000 lbs) and pulling an 18,000lb 5-th wheel. I will buy a 3500, diesel, 4-door dually.
Here are my two questions. 1) In my area I have found a few low miles 2012's. Any issue with that year? 2) I am inclined to go with a manual tranny. Will a big trailer like mine be too much for the clutch? Would I be better off with the Allison?
rraulston
Sahuarita, Az
2018 Ram Rebel
I would not do a 12 Cummins truck. 13s now have better emissions. Also, I don't think a manual will be an option for you. I think they quit making those....could be wrong though...
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
They still make a manual cummins just not gasser.
$miley
Stangshcky12
Oshkosh, WI
5.9 Cummins
I cant imagine towing 18,000 lbs with a 6.0, I tow 13k lbs (almost 23k combination) with our 6.0 with a manual trans and its a dog lol
I prefer manuals as I'm usually towing through back roads rather then highways
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
Well, don't worry about the clutch.
I am sure South Bend has something that will hold it if the factory one won't.
Stangshcky12
Oshkosh, WI
5.9 Cummins
The manuals do have less power because the stock clutch cant handle the power of the HO engine reliably and a clutch that can is very stiff and noisy as well
But the upside is they have much steepier gearing especially 1st gear
The G56 flywheel are known to warp with extra power as well
Peattie
Las Vegas
Would a 13 with the new heavy duty trans be the best option? Im kind of curious as well since my dad keeps talking about getting a big toy hauler. I may have to upgrade like what birddog did because he doesnt want to give up his raptor lol.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
If you can afford it I would get the Aisin which you can for now only get in the 3500. That transmission I believe has comparable reliability to an Allison which is really all GM has to lure people because the engine has nothing on an inline six. I am not sure what max power rating is as far as tuning goes but I am sure it is sick.
$miley
jlb
MT
CTD
I would go with the manual. I just feel that you have so much more control over a manual than an automatic, especially when towing. You have 0 control over "clutch engagement" with an auto, and that really bothers me when I tow with my 1/2 ton as I have never had an auto before in my life.
Also, if you could still find a programmer out there that has't been sent back to the manufacturer you could delete the emissions stuff, but you have to look around for a used one since all the new ones were shat on by the EPA.
jpex
cummins 6.7
u have to go auto, the manual has a max GVW of 14000 or so and the auto is 24000 or damn close to it
Stangshcky12
Oshkosh, WI
5.9 Cummins
Do your mean trailer weight or GCWR?
An auto hemi with 4.10 can pull a 14k lb trailer
A crew cab 4x4 drw with a 6 speed and 3.73 can pull 17,740lbs
Same truck with an auto and 4.10s can pull 29k lbs with 37.5k lb GCWR
that white kid
stay away from the allison my dad had a avalanche and the trans went out at 2700 miles and the silverado that my brother currently has went out at 500 miles and both trucks were brand new with no towing at all within those periods
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Well those are probably not an Allison transmission as I don't think they ever put them in the Avalanche and they are not in 1500 Silverado's just the heavy duty trucks. Allison is regarded as the very best my most.
jpex
cummins 6.7
i was meaning total payload/trailer but the numbers were also off the top of my head i just remembered when i was purchasing my truck the manual had a much lower capacity than the auto, auto's are also a much stronger design than most standards (look at heavy equipment) but to each their own, my car is standard and i love it its all personal preference task and price dependant of course. OP just make sure what ever your buying that it is rated for the task at hand
LovMyRam
Abilene, TX
2013 QCSB Black Edition, 2014 RCSB.
Allison was never equipped in the Avalanche and only the 2500/3500 series coupled with the Duramax got the Allison.
Correct, it hauls damn near EVERYTHING in the military. Could you imagine a dodge RAM cummins coupled to a allison, I'd be all over it.
OP I'd base it on how much your going to be towing, how often, and your driving habits/conditions. I'd say a lot more variables come into play but coming from the diesel/towing crowd (parents own a towing company) I despise towing with an auto. It makes some things more simple but generally ends up costing you more in the long run. That's my personal opinion though, we do heavy duty towing and I'd chose manual over an auto in most cases. The Aisin for dodge is made in Japan is it not? If that sort of thing bothers you. In my eyes if your going diesel, there isn't a better name than cummins, so at least you'd be on the right road their.
southalum
