truckmen
- Mar 22, 2013
- 35
- 5
- Location
- Bucksport, Maine
- 2014
- 6.7 diesel
Hello all,
2014 Ram 3500 6.7, G56-transmission, DRW- Fuel Starvation Issue when pulling heavy loads...
Years ago when I was putting several tens of thousand miles on this truck annually, I constantly ran into what I am sure was a fuel starvation issue. I changed fuel filters and fuel/water separators till I was blue in the face (especially during winter months in many-a-rest area).
This would happen whether I was pulling my 18,000lb 5th wheel camper or a fully-loaded 4-car Wally-Mo trailer and normaiily not when I wasn/t towing anything. Luckily, I believe no damage happened to the engine or high-pressure fuel pump. So, I am thinking, because I was creating such a demand on the engine, the lift pump just could not handle that demand. The truck has been parked with very little use during recent years as I was away working at sea. Now, that I am beginning to use the truck again, I fear I will have this problem. I am preparing to go with the FASS fuel system, particulary the following:
FASS Titanium Signature Series PLUS 250GPH Fuel System for 2005-2018 & 2021-2024 Dodge RAM Cummins 5.9L and 6.7L (1000-1200hp)
FASS No-Drop Series PLUS 100GPH Fuel System for Dodge/RAM 2005-18 & 2021-24 Cummins 5.9L & 6.7L
By the way, ChatGPT says the following about the stock lift pump capabilities:
Any thoughts?
- Roughly 25–35 gallons per hour (GPH) at ~10 psi.
- This is enough to feed the CP3 high-pressure pump at stock horsepower (350–385 hp at the crank in that era).
Any thoughts?
