1ST GEN Picture Thread
mykdee
Litchfield Park, AZ
I have searched and can not seem to find a 1st gen pic thread! Am I just not finding it?
MADDOG
Living in a Firepit
Go ahead and start one.
1500ram12
5.9L Cummins
Here's my 90 w250 12v cummins in it's current state
The 93 w350 gasser parts truck which may end up getting built also
And the 92 d150 I just picked up. I'm going to use the body for my truck
2018 2500 6.4L Hemi Tradesman
1990 5.9L 12v Cummins W250
mykdee
mykdee
Litchfield Park, AZ
Your 93 definitely looks nice enough to restore or build.
1500ram12
5.9L Cummins
The 93 is rough. Looks good from a distance. Needs floors, and rockers front cab supports. A patch on the drivers side fender. The bed wheel arches have the patch panel glued on and bondo over so they'd need to be redone and the bed supports need replacing. Previous owner put a different trans in and couldn't get it to properly down shift. But maybe a later project.
The 90 has been 99 percent a complete restore. Phase 1 replaced axle seals bearings/races u joints, all new brakes (rotors, drums, calipers and supporting hardware) new brake line's, fuel line's. New u joints on the driveshafts. Will have new manual locking hubs, shocks and tires. Basic replacement parts on the motor (fuel pump, water pump, Thermostat, belt, belt tensioner, alternator, switching to a 91-92 radiator and Thermostat housing, new oil pan, engine mounts, gaskets). Replacing the floors, rockers, cab supports. New body mounts. Leaving the trans mostly untouched because I plan on manual swapping at some point. Body, I like the patina aged look so that's why I bought the 92. Phase 2 will involve pulling the motor and rebuilding it. It's only got 120k on it.
For a more in depth look at my build here is my build thread
My 12v cummins build
https://r.tapatalk.com/shareLink/to...ns-build.163071/&share_type=t&link_source=app
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
frame off is the way to go. a little more work at the start but way easier to get everything done and done well.
I ended up building one of my parts truck up as well during my project. Now I have 2 old trucks, will probably sell one at some point.
noraa73
