2/4 belltech lowering kit
az88
saudi arabia
hey guys, I just wanted to take your opinion on the 2/4 belltech lowering kit on a 2018 2wd single cab 5.7 ram are there any negatives about this kit
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
It's a decent kit, some have challenges with it as it moves the rear wheels forward and creates some high-speed instability
natehate
ontario
i'm gonna piggy back on this post
964SP 2/4 kit with street performance shocks vs 964ND 2/4 with nitro drop shocks.
every pic i've seen of the nitro kit shows it with sway bar links and the track bar relocation bracket.
pics of the street perfomance kit just shows, springs, shocks and bump stops. no links and no bracket
is anyone familiar with what you actually get with these two kits?
21 classic short box reg cab
Bigskyroadglide
Moderator
Order the 964nd kit with the track bar relocation and end links, they are necessary. The shocks will likely last about a year before they need replaced. You will need different bump stops. Which comes in the kit. It's a fairly common kit
natehate
ontario
does the sp not come with those parts?
Bigskyroadglide
Moderator
Correct. I would also tell you, I ended up cutting my front bump stop cups off and using a different item as I still bottomed the front suspension at higher speed. Removing the cups,and using a different bump stop significantly reduced bump steer.
natehate
ontario
thats weak of them not to include those parts. what different bump stops did you use?
natehate
ontario
update, the 964sp came in yesterday and has all the parts in question in the box.
natehate
ontario
A few months later... How's your experience been with this kit?
it's good, i had to bend the gas tank shield a little. it was rubbing on the drive shaft.
i've bottomed out a few times. but that is part of the life
for the most part it rides very smooth.
love the stance.
oh i did use different front bump stops then the ones supplied
i believe that is the one i used..
i would like to add some ihc brackets, but with them no longer making the no cut kit that wont be happening anytime soon.
also want to add core4x4 control arms. but will probably do that when i do the ihc bracket kit
wes8398
Ontario, Canada
love the stance.
Appreciate the feedback. Are your wishes to do the brackets and control arms due to instability issues? Do you think the bottoming out issue is from the control arm mounts hitting the frame, or bump stop contact? Maybe removing the entire bump stop/cup and replacing with a smaller unit would help...?
natehate
ontario
i wanna do the bracket kit to have proper control arm angle. i'm not having any instability issues. i did add a 3/4 rear sway bar at the say time as the drop.
i'm not 100% sure whats hitting when it bottoms out. havent had a chance to get under it and see.
the only times its bottomed out has been hitting LARGE bumps or train tracks at speed that i didnt see coming in time to slow down
wes8398
Ontario, Canada
Thanks for the info. Trying to map out my plans for converting my Rebel w/ air suspension to a 2/4 drop kit. A lot of mixed info out here. And since lowering isn't common, the waters are a bit muddy.
natehate
ontario
yeah i dont have air suspension, so not sure how much my info will help
my truck is also reg cab short box
cdub5
