2" Level - 35" Tires
swanny297
I have a 2014 blacked out express - I am adding the bilsteins up front and would like to change the tires - I am going with Mickey Thompson Deegan tires but would like some thoughts on size - 305-55-20 or 35-12.5-20. I have read through lots if topics some say you need a spacer some don't to run the 35. What so you recommend?
OilCityOperator
Alberta
305 55 are 33s, what wheels are you using if your using factory wheels they are 19mm and you will need spacers for offset
longsidelandry
Delcambre, LA
I just installed some 295/65 r20 Toyo AT2 Extreme on my 13 1500 on stock chrome clad rims with no spacers. The only rubbing is at full lock in reverse.
ETA: I also have the Bilstein's set at 2.8
S
swanny297
It is a 14 express blackout edition - it has the 20x8 wheels - stock tires are 27060R20 which are 33". I have 2.25" of difference in height front to back - I would rather go with 35x12.5 tires and if I need spacers I want to make sure I have them so they can be installed with everything else
Revo
Canada
5.7L
I have a 2.5" level, 35" x 12.50" Toyo M/Ts on 18x9 ATX Ledges (0 offset). Tons of rubbing, though only on the driver's side.
ItsMeKO3
Canton NY
I read somewhere that Toyo MT's and Nitto Trails actually measure out to 13.4" wide.
S
swanny297
I decided to go with a 275 65 20 tire a little taller but I won't have to worry about spacers or rubbing
