2" Mcgaughnys drop vs CC w/ 32 gal tank
LoneStarHemi
2014 RAM 1500
My 14 CC w/ 32 gal tank has a factory drivers side rear spring which is about 2" taller than the pass side. When installed the truck is level. The Mcgaughny springs are the same size L and R and sure enough when installed the drivers side sits about 2" lower. Anybody else run into this?
Avgas
2015 Express
3.6 Pentastar
Get a 2" spacer
Sent from my 2PS64 using Tapatalk
VB712
Maxi_built
Va Beach
I have a CC with 32 gallon tank. Used the 2" drop springs on mine. Driverside is only about 1/4" lower than passenger side.
EJR_3
North Las Vegas
6.7L Cummins
If there was a 2" difference in the spring and the driver spring is lower, installing the stock passenger spring on the driver side might fix your issue. Also, sounds like the weight of the fuel makes the driver side rear height fluctuate since the other user have a different measurement. A gallon of water is about 8.34lbs. So 32 gallon tank would hold anywhere up to about 266.88lbs of fuel. Just thinking out loud, so take this as a grain of salt.
