20" Rigid LED SR2 Driving installed
jadocs
After seeing some of you guys with your LED setups, I was bitten by bug. Since I have cab lights, I was limited to mounting the bar between the tow hooks. My next decision was what size to get. I spent a lot of time researching the specs of the different manufacturers (size/lumen output), and ultimately decided on Rigid. I didn't want to pay full retail if I didn't have to, so off to eBay I went. I found some Rigid tow hook mounts for $66.45 and a NIB SR2 20" Driving LED for $500. What I like most about the Rigid mount is it allows you to adjust the mount laterally before they are tightened down, and the LED bar can also be adjusted up and down to find perfect center.
Before I received the 20" SR2, Driving LED, I was skeptical about the output. Rigid claims 11,250 lumens. My doubts were quickly erased this evening.....WOW. This pic is just the LED bar.
jadocs
jadocs
Looks good I run Rigids as well. Worth the money IMO.
Thanks SB, I just ran the factory harness and used the switch that came with it for now. I still have these I need to put in.
Did you modify the existing harness on yours when you tapped for triggers, or did you just make your own from scratch?
jadocs
jadocs
From outside the truck. I have to say that I was initially worried that a single row 20" wouldn't be that bright.
Jantelaw
