2001 Dodge Ram 1500 rough idle in Park and neutral only
Ram_808
hey guys,
Stuck on my truck !!
Symptoms initial morning start up
- rough idle in Park and neutral up and down between 200 and 800 rpm almost a back fire .
- when put in gear perfectly fine drives good no hesitation
- after initial start up when put back in Park or neutral seems fine.
Work done.
- cleaned TB
- changed IAC
- reset comp
- changed plugs
- checked vacuum lines
Any help or direction would be appreciated
Ram_808
Ram_808
Got it fixed!!
Changed out both crank and cam shaft (distributor pickup assembly ) sensors . Idles perfect..
