Grant young
- Nov 23, 2024
- 4
- 2
- Location
- Tillsonburg ontario
- 3001
- 5.2 magnum
Hey everyone I’m new here and am getting a truck from my parents. It’s a 2001 ram 1500 with the 5.2l auto. I believe 42re. The issue I’m having is it has all forward gears with no reverse. If you put it in reverse it will only move afew inches but then stops like in neutral. I tried to speed up in 1st gear to 30 mph and check engine braking but couldn’t tell. I checked fluid level which was in spec. I removed the trans pan and found no abnormal metal wear or any snap rings or chunks of metal in the pan. I put a new filter in while apart. When pushing on the low reverse rocker I can see the band move and the strut looks to be in the right place but when I applied the rocker I noticed it comes away from the servo about half an inch. I adjusted the band adjuster within spec. I couldn’t see any cracks or anything in the servo piston but I didn’t remove the retaining ring so it was hard to see the piston. I put the pan back on and fluid in and found I still have no reverse. Can anyone steer me in the next direction I should go and have any recommendations.
