JHensman
Hello,
I just did a transmission flush on my 11 Ram 1500. I followed every set in the manual. Transmission is serviced to the right amount to include all pressures are correct. I double check with my snap on computer.
The problem that I am running into is that I have no reverse gear. Everything on the drive side is working fine at this point. I have tried everything that I have been able to find on Google, including re-dropping the pan to make sure that the filters are primed and installed correctly.
The only inconsistency that I have been able to find that is not acting the way it is supposed to is that my LR pressure sensor is working correctly in first gear and closes when I shift 2/ second third fourth and fifth. But in reverse the sensor is saying open when it should be closed it does not make sense to me why a sensor would be working for four but not reverse. The only other inconsistency was that when I have a computer hooked up to my truck and I shipped it to reverse the computer says that the truck is sending the signal for reverse, but it is still in neutral.
I have checked all my pressures and I did not do anything with the torque converter or the valve body inside the transmission. So there’s no reason any of that should be bad when it worked perfectly fine yesterday before I changed the fluid and filter filters.
I’m sorry for the long post, but I’m at a standstill and don’t know what else to do. I am hoping that somebody on this forum will be able to give me some advice.
Thank
Josh
Thank
Josh
