mopar44134
So I picked up this Ram not long ago and of course it has the tick. Runs good, crappy mileage though, 13mpg. 145k. My dakota 4.7 with 3.92's gets 17. This has 3.55s. I am currently using the truck as a daily driver back and forth to work, with plans to pull a car trailer and my 68 Barracuda to the track. I had a 2002 with the 4.7 and 3.55s, it pulled it ok, had to down shift on that hill on 71 by Lodi in ohio going to dragway 42.
BTW and it has nothing to do with this post, just bragging, if you want to see a picture of the Dakota, its on the ad for dragway 42's hang over race this year. Made the semi finals!
Back to the point, I plan on changing the cam and lifters. I've read here the valve springs maybe a concern, but i figure with the head off change those to match the cam.
I've been searching threads and have a few questions i'm hoping someone will answer.
Will I be able to tune the pcm? I've read hear about swapping to a 2005 pcm, with wiring harness swap. Is this a plug in mod or will wires have to be traced/spliced.
Which Cam? I heard mixed review about a 6.4 cam swap. Seems to me this is more geared to chargers/challengers, Hp rather than torque.
Which Lifters? 6.4's
Any head porting tips to help add torque?
While im that far in, what else should i do?
This is a non-mds truck, right?
I also read about pulling/cutting a yellow wire for the tcm. I'm not very clear on what that does. As it stands right now, this truck seams very docile off the line unless your foots in it.
Thanks in advance!
Thanks in advance!
