2004 Ram 1500 3.7 (6 cyl) a/c won't blow
chicken 1492
3.7l v.6
My truck's a'c will not push cold air. I have replaced resistor and blower motor, and those didn't fix it. Also, it is not a blown fuse issue, as they are all good. The blend door is not broken even though it is an original part. Saturday, the 4th, it would work after the hood was slammed but yesterday it wouldn't work at all. The clutch would still engage but no air would be pushed with any pressure. It was still cool air but it would only move a little bit when we were moving forward.
Also, occasionally the switch for the fan select can be turned to the "off" position and the yellow/orange light above the button for cold air will be on for up to a few minutes.
Please help, because as it gets hotter here in Texas it can start to get unbearable, even with the windows down.
-Thanks
