2004 Ram 1500 Rod Knock
shanede54
I have a rod knock and I am wondering if it is possible to replace only the bearing that is knocking? Someone please help!!!
JAMMAN
Brace yourself for some major headache. Normally bearing slop is accompanied with scoring of the crank resulting in the crank having to be ground and undersize bearings. Usually cheaper and better to get a used motor or crate motor and just plant it in.
If it is knocking chances are the damage is deeper than just the one item knocking. Way deeper.
S
shanede54
I was thinking the same thing...Thanks for the input!
