2006 2500 Cummins 4x4 TIPM issues
DwnSthCummins
Gulf Coast
Cummins
My TIPM is acting up, no low beams, a/c comes on when it feels like it, rear defrost does the same and it acts kinda of hairy some days. Did the diagnostic troubleshooting procedures and the TIPM is junk. My question is this, I have another exact 2006 2500 Cummins 4x4 With the exact same options and the same exact part numbered TIPM P56049, can I use this one? Also do I need to have it programmed/flashed?
Thanks for you help in advance!
MADDOG
Living in a Firepit
6.4L HEMI
Should be plug and play with an exact replacement.
Gman75
Washington
5.9L
Thank you! Swapping it out now!
Did this fix your issue? I have a 2006 Dodge Ram 2500 with the 5.9L cummins. AC comes on whenever it wants to, same with rear defroster, airbag light is on all the time, and now my tach is reading 100 rpms at idle (sometimes it goes back to normal). I am ordering a TIPM to throw it in sine i have found this to be common in failing TIPMs.
ChloeBrooks
