2007 Cruise inop...
karkrafter
Dalton Ma
2007 4.7, When you turn the cruise 'ON' with the left hand control, the light most often comes on for about 1 second then shuts off, if it stays on longer it shuts off when you try to engage. Sometimes the ON light NEVER comes on.
I have replaced the left control and clock spring...doesn't seem like it should be the brake switch, seems like that should not control the on/off of the unit itself.
Any ides?
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
If any engine light is on in the instrument cluster, Cruise will not function
karkrafter
karkrafter
Dalton Ma
i didn't know that buuuut, that is not the problem.
ZtripleZ
Scio, OR
Were you able to figure anything else out on this? I'm having the same issue where my cruise light comes on and then shuts back off. My truck didn't have cruise control and I just added the switches so I'm still looking to see if I was supposed to add anything else as well.
