2007 ram 1500 ac barely blows but I hear it going good
Hesabiggin111
Oklahoma
4.7 v8
2007 ram 1500 2wd with a 4.7l. I hear the AC blower motor blowing but barely anything coming out the vents. Please help it's 110° I'm dying. Also I need to replace my passenger front wheel hub and I have one but it has a sensor on it and my truck doesn't have a sensor. If I remove the sensor and plug the holes will it work?
BOWERSFJ
Uniontown OH
You’re in 4th Gen territory ... You’re 3rd Gen with a 2007
H
Hesabiggin111
Oklahoma
4.7 v8
Sorry how can I move it to the 3rd generation or delete it and start over
indept
South Jersey
No matter which gen the troubleshoot is similar. 1st is the compressor clutch engaged? If yes then are the hoses / pipes really cold, 1 coming off the compressor should be cold and 1 very hot. If no then a freon issue. If yes then your vents under the dash aren't working properly.
nick heilman
West Bend WI
4th gen here but i bet on your 3rd gen the blend door isn't allowing air through. They are notorious for the doors and actuators inside to fail. look up blend door fix on google for your truck and you will most likely find a lot of similar issues
