Gillman
Trying to understand the vent hose operation with vent cap extended from the drivers side rear axle to up under the wheel well..
Repalced the gear fluid and pinion seal, while doing that checked the hose and it seems you need to put a fair amount of air threw it to confirm it “vents”
I can’t blow through it with my mouth, although I can with a quick short blast with the air compressor.
should there be some resistance or should it be as clear as a straw?
also, the vent plastic white breather at the end is clear and I checked it, it’s not a “check valve” as some have claimed, you can blow and suck in and out no problem with that device.
don’t want to fix something that’s not broke, thought maybe my pinion slight leak was maybe the vent clogged.
TIA!
TIA!
