2008 4.7 volant cai
inktoxicated
nj
hey guys. anyone with a cold air induction have any idea if this problem, will be a PROBLEM? i bought my truck used and it had a volant cai. 4.7. after taking a closer inspection at it i noticed that the breather hose ran from the air intake nipple down thru a hose into the valve cover but the hose was kinda jerry rigged into the valve cover because the nipple was snapped off. its a semi snug fit into the hole. u can see where the nipple was broke off. will this be ok? or does it need to be 100 % air tight? truck runs fine. was thinking maybe getting a small peice of pcv pipe and epoxing it over the hole. then it can act as a nipple. or should i not even bother
