DiGangi
Greetings. 2013 1500 4.7 engine. A little back story and this is embarrassing but here goes. A few weeks ago I was going to head out on a little 200 mile trip pulling a small travel trailer that we have. Prior to the trip I wanted to top off the Windshield Wiper fluid. I was not paying attention and I put the windshield wiper fluid into the coolant overflow tank, and quite a bit of it I might add. Anyway I was none the wiser and headed off on the trip. About 100 miles in going up an incline the RPMs jumped up to 4000 and the temperature gauge went into the red and stayed there. So I had to limp back home at 30mph stopping every so often to let the truck cool. When I got home I flushed the system figuring that would solve the problem, it didnt. I got a code, and I cant remember the code right now for low voltage on the Coolant Temp Sensor. So long story short so far I have replaced the sensor, thermastat, fan clutch, flushed and vaccum refilled the system. If the truck idles temp is fine, as soon as I start to drive it then it goes over into the red AND the heater is only blowing cold air now, no hot air. A couple of other things, the connector broke when I was replacing the Temp Sensor but it still snaps in and I was able to clear the code and it has not returned. When I vaccum filled the system after flushing I forgot to run the heater on high as per the instructions when I was doing it. Also, oil looks fine, not milky so I assume it is not the head gasket. Top hose is hot after running it and bottom hose is only warm to the touch. Plus the radiator cap doesnt seem to be hot and is definately not blowing steam in spite of the truck telling me my coolant temp is up over 250. I am at a loss as to what to do next...water pump replacement or radiator replacement??? Any help is GREATLY appreciated.
