2009-2018 Dodge Ram Black/Smoke LED 3rd Brake Lights
Underground Lighting
Supporting Vendor
This product is a replacement and upgrade for the old third brake light, smoked lens pairs up the tinted rear window with dark appearance as opposed to the clear lens, a popular way to customize the rear appearance of your truck.
  • Compatibility: for Ram 1500 2500 3500 2011 to 2016, Dodge Ram 1500 2009 new body model only and Dodge Ram 1500 2500 3500 2010, not for Dodge Ram 1500 2009 classic body model, not for 2016 and up models with Camera in 3rd brake light.
  • LED lights provide better visibility for the rear lighting, brighter than the dull and dim halogen bulbs, new design of double row LED, 9 red LEDs for brake lamp and 9 white LEDs for cargo lamp to illuminate the truck bed, especially at night.
  • 0.2 inch (5mm) foam gasket included as an ideal solution for the water leak problem, thicker than old foam but will leave some gap outside between the housing edge and truck body after installed, it won't void the waterproof function for protecting the inside part
  • Package includes 1 light assembly with direct fit plugs to your truck's wiring, no need to slice anything, easy to install, manual included, read before installation
  • Plug-N-Play Operation, Low Power Consumption
  • Super Bring LED Light Compare to The OE Light
  • Brings a Different Appearance to Vehicle that Great for Show Use
61HDAqYwlnL._SL1000_.jpg 61LTUYKh40L._SL1000_.jpg 42058606_1117035268454380_3928304262903234560_n.jpg IMG_4403.jpg
Rico31286
Will it fit a 2018 ram 1500 classic body
