New Product Alert! Brightest LED Reverse Light Bulbs!
Underground Lighting
Supporting Vendor
Underground Lighting brightest reverse led bulbs on the market. These are designed to last and are just as bright as a headlight!Upgrade your vehicle’s reverse lights with Underground Lighting’s brightest and most reliable LED bulbs.
Backing up safely shouldn’t be a gamble. Our reverse LEDs deliver headlight bright illumination, durable construction, and plug and play installation, giving you confidence every time you shift into reverse. Designed for OEM and aftermarket tail lights, these LEDs fit snugly, resist water and corrosion, and produce extreme white 6500K light for maximum visibility.
921 T15 Reverse LED Pair
Rated Power:
50W per pair Lumens: 10,000 LM per pair LED Source: 6x Osram LEDs Color Temp: 6500K Extreme White
Why You’ll Love It: Compact size for tighter tail light housings, quick plug-and-play installation, and reliable waterproof fit
921 T15 LED Reverse Light Bulbs
7440 Reverse LED Pair
Rated Power:
60W per pair Lumens: 12,000 LM per pair LED Source: 6x Osram LEDs Color Temp: 6500K Extreme White
Why You’ll Love It: Maximum brightness, fits medium to large tail lights, CANBUS compatible, and fully waterproof for all conditions.
7440 Led Reverse Light Bulbs
Shop 3156 Reverse LED Set
3156 LED Reverse Light Bulbs
What’s in the Box?
Two premium reverse LED bulbs Foam gaskets for moisture protection Aluminum collars for a secure fit.
Tube of dielectric grease to prevent corrosion
Step-by-step instructions with QR code for easy guidance Installation Made Simple Remove your tail lights (screws or push pins, depending on your vehicle).
Swap your OEM bulbs with the Underground Lighting LEDs.Install gaskets and screws for a snug, waterproof fit.Position LED chips for optimal brightness.Test and enjoy safer, brighter reversing immediately.Why Drivers Love These LEDs Bright enough to see every obstacle behind you Durable design keeps moisture and corrosion out Fits most vehicles without error codes Quick, stress-free installation even for beginners Upgrade your reverse lights today and drive with confidence. With Underground Lighting, every backup is safer, brighter, and worry-free.
Product Video and Installation Steps
