2009 air conditioner?
hemishark
Does anyone have any suggestions for my AC? It's blowing warm air and the compressor does'nt seem to be engaging. I did'nt see anything listed on the fuse box?
Thanks for some advise.
hemi crew cab
BlownGP
Houston/Baton Rouge
You might need to have it checked. Probably low on refrigerant.
B-g-K
Upstate NY
Ecodiesel
You might need to have it checked. Probably low on freon
Compressor would still kick on though. Hopefully the refrigerant being low is his problem though, cheapest route.
12_Ram_CC
Indiana
Unless I'm mistaken the refrigerant also acts as a lubricant for the system so could be an issue or have created an issue...?
Burla
2010 Hemi Reg Cab 4x4
Nothing came out of mine when mine broke, no air at all, it turned out to be a resistor motor. I had it under warranty, but they guy said it was like a 100 dollar part and no big deal if that is what it is.
H
hemishark
I guess i'll take it to the dealer and have it checked and decide if it's worth having them fix it.
powderbrad
Edmonton, AB
2 stainless lines ont he pass side of motor. One, when AC running should be frosty cold, and the inner one (closest to block) should be warm.
If the outer one (closest to fender) isn't cold, you have no refidgerant running, which would make sense if your compressor isn't running.
Could be the switch itself in your dash not kicking the compressor on?
Orca
