2009 hemi Laramie 4x4 crew - 204k miles
EMDubYa
Just moved to Denver from Houston and had truck hauled up, too. Before I left TX it started having old truck issues, loose front end, mds crap, and well.....it just seems like power is going away, and it's just running like crap overall. Here in Denver the other day I was climbing a hill after a car wash and the trans seemed to struggle to find a gear. Next day.....no issues whatsoever. I love my truck and don't want to ditch it just yet (especially with the unlimited mile/year power train warranty), but man am I getting nervous these days. Any suggestions for a high mile 5.7 4x4?
RamRoy
Crestview, Florida
With the lifetime powertrain warranty, take it in. I also have an 09 4x4 with 173,000.
If it is powertrain issues, take her in
ColdCase
Denver is a higher altitude than Houston, many vehicles seem to run like crap there.
How many tanks of fuel have you gone through since it started running like crap?
How clean does the throttle body look?
Any debris in the air filter box?
Anything clogging up the exhaust?
Look for vacuum or brake booster leaks as some of those rubber things get brittle over 10 years.
Take a look at the plugs
Any brakes dragging?
Otherwise you may have to run a compression or leak down test to get a picture of how well the valves and rings are sealing. But check the simple things first.
E
EMDubYa
Thanks Cold Case. The problems actually started back in Houston with the MDS acting up. Several trips to dealer netted me a response of ‘shift to 5 and drive that way’. And its worked for quite some time. But now there are these new issues.
Plugs were changed last spring. Air Filter is replaced and intake tube examined regularly. Throttle body was cleaned recenty. Drove through high water during Harvey but nothing that would have gotten into the motor or trans.
Haven’t checked thoroughly checked the hoses but they don't appear to be in bad shape.
Not sure what you mean by brakes dragging. The brakes in this truck have been NOTORIOUSLY terrible after the initial brake change. Constant shuddering and brake fade and pedal is near the floor to stop from 60.
I will say that the coolant levels are seemingly always low (radiator replaced 4 ears ago) but yet I find no evidence of coolant in the oil.
Thoughts?
Pull Ya
Cedar Creek, Tx
Excellent Ram 4x4 mechanic in Ft Collins(just north of Denver), Colorado 4 Wheel Drive, owner is Kurt Zimmerman. In business for about 35 years.
Jay
huntergreen
Marine Corps Navy Badge
What shape is your battery in ? Funky things happen if the battery isn't working properly.
huntergreen
Also sounds like your dealer in Texas screwed you. MDS is part of the drivetrain,should have been fixed, not told to shift into 5th gear.
E
EMDubYa
Jay
Thanks! I'll reach out to him for sure. Really appreciate the info!
E
EMDubYa
Battery is new. I've had the same problems on my '04 so that is usually first place I look when problems pop up.
RamInfo
Utah
5.7L HEMI
Just on general principle, at that mileage I’d hit NAPA and get a can of BG44. Run it through next time you’re doing a longish road trip. Also, you’re now a mile high which is probably quit a switch from Texas. Your truck may have some learnin’ to do?
Best,
DG
E
EMDubYa
No. The issues started prior to that.
averageguy
Belleville Mi
hemi
Thoughts?
If you are finding the coolant low and having to fill it up either it is leaking it somewhere externally, or its going into or through the engine and out the exhaust. A slight leak can evaporate and not be seen on the ground, and a minor internal leak can go out the exhaust and not be noticed.
indept
South Jersey
Also it could be the radiator cap not holding pressure. Antifreeze will boil off slowly if cap isn't holding pressure
