2010 for 2013+ steering wheel swap
GutsGloryRam1500
HEMI 5.7
Just got a 2010 and the steering wheel is on the nastier side. Its got the factory steering wheel controls on the front the eic and back for the radio was wondering if I could swap it for a 2013+ one and get both a new wheel as well as the newer style. controls and ditch the cruise control lever.
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
You can get a new wheel, doubtful you'll be able to ditch the cruise control lever unless you go deeper, probably at least a clock spring, maybe more. You need a wiring diagram at minimum
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I don't believe they are compatible. Electronic configuration changed in 2013. You'll likely need a 2009-2012 wheel.
