CostaRam
So,
i pulled my 2011 1500 5.7l out of the storage after 6 months of no use and battery disconnected.
Battery had a solar panel charger attached and car fired right up and voltage gauge showed usual half (12 o'clock position)
I used it driving for some miles, went to groceries shop, etc, car was fine.
A bit of rough ideling when firing up, but driving fine.
Yesterday morning i went having breakfast and on the way there i noticed that the truck is stuck in 4th gear even if selector was in D.
When after breakfast i wanted to drive home and rough running was worse and still stuck in 4th gear.
I noticed also that the gear number on the evic was on or off and there where also some problems with the radio rebooting spontaneously (but this is a old problem).
Then the truck lost all power and almost died but i made it to drive on the side of the road, truck died and did not started anymore.
Symptoms are:
- Turning the key to start position the radio will switch off and starter will not turn
- radio showed "Insert Security Key" screen, not sure if this relies to radio or immobilizer
- waiting a hour or two the engine will fire up but die immediatly
- red round light blinking is continously blinking
- locking/unlocking doors don't change anything and is working fine
- trailer brake disconnected warning message
- trailer brake control box is blinking
- battery gauge show half way between 1/4 and half (but was before always on half)
- battery has 12.4V
- attaching other car with jumper cables and running engine did not help
- voltage on the entrance of the fuse box is 12.4V
- on the green line showing the gears, the R is in red, but i cant remember how it was before
- headlights are bright, cabin lights too and don't dim while turning key to start
- clicking sound of a few relays in the fuse box when ignition is on or turning key to start
- jumped negative terminal to chassis, problem persist
So i thought that battery went bad, bough a new one, installed it and truck fired up but died immediately and then will not turn over again
Checked fuses and they seem to be fine
Had the truck hauled home and charged the battery over night till full and truck for 12 hours without battery connected.
Installed battery this morning, still same problem as above, starter will not turn
Voltage gauge showed a little more but still not in the center as normal
I am still convinced that the problem is either:
- bad voltage for ECU and/or bus and this can lead also to the problems below
- the red blinking light show that immobilizer is in and this avoid starting the engine
- the red R means that the ECE think gear is in R and this block starting the engine
is there a voltage regulator or similar device feeding the power to the dashboard/radio/bus/ECU
is there a way to measure voltage on the bus/ignition key/ignition relay
Is there a way to reset the ECU completely?
I'm in Costa Rica, dealership is 60 miles away and i would like to pay big $$$ for a simple fix i could do.
Thanks so much for your help!
Chris
Symptoms are:
- battery has 12.4V
Chris
