PapaGoose
Good afternoon everyone.
Beginning of the issue is about 35k miles ago, I rebuilt my engine, replaced the transmission with a brand new 68RFE. Used mopar trans fluid naturally.
Been having the P0934 hydraulic pressure sensor circuit low code, transmission sometimes shifts hard, sometimes doesn't seem to want to shift. But the fluid is at full mark, doesn't smell burnt or look bad.
I've tried replacing the sensor 3 times, 1 ac Delco, 1 sensor, and one other brand that I cannot remember the name of it.
Possible that I got 3 bad sensors sure. But when I replaced the transmission my tuning software couldn't read the TCM do I could do an electronic relearn, had to do it manually.
A couple of months ago a friend of my one used his expensive ass snap on computer to do the electronic relearn from my transmission and it stuck for maybe a day? Then the code came back.
I just got back from driving supplies and gasoline up to asheville NC after the hurricane. I spent 2 days up there and drove around a LOT engine on and off. Not one time did the code come back while I was in the mountains, but as soon as I came back down the mountain it came back and has stayed on since.
Could this mean an actual pressure issue? Maybe the elevation/reduction in outside pressure helped and that's why the code stayed away? (Also trans shifted sooooo much better while code was off, truck felt almost brand new compared to how it is most of the time where I live)
I've also conductivity checked the wiring and it all seems good as well.
What would you guys suggest?
