2012 Ram DTC codes P0344, P0340, P0301 along with TCS light
2012TryonRam
Denver
My Ram is continually throwing:
P0344- Cam Shaft position sensor signal intermittent
P0340-Cam Shaft Position sensor circuit bank 1
P0301- Cylinder 1 misfire
it also turns on the tracktion control light and no longer shift correctly
I changed the cam shaft position sensor with one from Autozone. The connector looks good. i read on other threads that it could maybe be the oil control valve. Please any help
Thanks guys . This website had helped me before hopefully it can again
2012TryonRam
2012TryonRam
Denver
Fixed it. After reading other threads, i went to my local dealer and picked up an OEM camshaft position sensor. about $20. put it in and cleared the codes. Bam! check engine like has not came back on
tantore
texas
some times is bst to use o.e.m. parts glad you fixed it
