2013 200 Rear Wheel Speed Sensor Gap
Fujiguy462
Halifax Nova Scotia
I have a 2013 2500 Cummins and have been having ABS issues. The scan says it is the rear right wheel speed sensor ( checked and the output was 0). Replaced the sensor and it is still happening, I am starting to check the harness to the ABS module but I have noticed the gap from the wheel sensor to the ring on the right is quite large especially compared to the left and I suspect it may be the issue. Has anyone seen this? My first thought would be rear wheel bearings but I don't seem to have any bearing noise. Would there be anything else that would cause the gap to be different?
