2013+ Amp Power Step Install - Help?
WhiteExpress
Midland, TX
I'm working on installing a set of these steps on my Dad's '14 BigHorn 2500.
The mechanical part, I have little / no concern about.
I'm working on the wiring first.
I've got the 4 purple wires into the cab, but I'll be damned if I can get to the harnesses I am supposed to tap.
There is a 'component' (best I can tell its the Alpine Amp) in the way.
From the instructions, it needs to be removed for install.
That's well and dandy, but I cannot seem to even locate the top mounting screw.
Has anyone installed a set on a '13 or '14 Ram and run into this?
Thanks in advance!
WhiteExpress
WhiteExpress
Midland, TX
Well, approached this today with a fresh head and far nicer weather.
It was the amp for the stereo, and it came right out. Just need a 7MM deep and a 6" extension.
This is certainly the most pain in the ass wiring project I've done to date. Yuck!
Westwind1124a
Maine
2024 ZR2Hd
6.6 Duramax
dang, my 2012 was easy. everything right into the fusebox… hope the rest goes well
boomer135
USA!
2013 Sport CC 4x4
I also thought the 2500's were wired to the fuse box connections. My 1500 had to be done the same way as the OP mentioned. I ended up using the wires in the drivers side kick panel. it was much easier.
WhiteExpress
WhiteExpress
Midland, TX
In '13 they started pulling signal from under the driver kick panel.
It's a mother f*cker to get in there.
I was all prepared to wire from the fuse box.
Guess another mark against the '13+ trucks.
