Cheap Apple Car Play upgrade
62Blazer
Midwest
I have a 2016 2500 with the Uconnect 8.4. My daily car and wife's vehicle have Apple Carplay and I really wanted that feature. Mainly for having maps/navigation come up on the screen versus trying to see the phone screen. After watching a couple YouTube videos I tried a cheap Amazon version made by Junsun.
https://www.amazon.com/dp/B0DB5N7P41?ref=ppx_yo2ov_dt_b_fed_asin_title
Here is a YouTube video from Boosted Motorsports
https://www.google.com/url?sa=t&rct...usg=AOvVaw1-7rWgT885uRv-GNcJ-XcY&opi=89978449
It took me a couple nights to get this installed (only working a few hours at a time).
The install is fairly involved. I consider myself a fairly advanced home mechanic as I've pulled transmissions, replaced via solder stepper motors on instrument panels, weld, etc... and would consider this above the comfort level for many people. This is not a simple unbolt the old system and bolt in the new one and not much in the way of instructions are included. All I can say is thank goodness for finding a YouTube video from a person that shows you what to do.
The new "radio" installs differently than the original and requires you to transfer bezels. This means you have to take apart the section with the stereo knobs and expose the circuit board to transfer over. The hardest part of the job was getting these knobs popped up with the concern of messing up the circuit board.
The wiring looks like a mess as everything is adaptor harnesses, but after plugging it in most makes sense. But again thanks goodness for YouTube videos to explain some things.
For fit and finish it looks fine. There is an issue with the climate control temperature down buttons sticking. This was mentioned in a couple places, so I was able to test fit and verify the issue. A few minutes with some sandpaper fixed the issue.
For function. I just got it hooked up last night and briefly tried it out. Need some more time to mess with it.
No issues syncing my phone and getting Apple Carplay up. Climate control works fine and settings will display on the screen. Initial audio sound quality sounds fine after listening a minute or two.
Current issues. I'm getting no reception from FM radio, just static. Will need to pull it back out and verify the antenna is hooked up correctly (currently have the "white" connector hooked up). Hopefully I just don't have it hooked up correctly.
Need to figure out how to program in the preset FM radio stations. The steering wheel cycles through the ones, but they are all the same default values.
The "voice activation" button on the steering wheel does not seem to function the same. This is the button you push if you want call somebody and then speak their name. Need to play with it more.
Have not tried out the radio mic to see how the hands free call quality is. There are some notes in the YouTube video of wanting a different mic that I need to follow up on.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwj_h6CZ57qQAxVCHNAFHUu5BZUQtwJ6BAgQEAI&url=https://www.youtube.com/watch?v=Sr9Jp990cvQ&usg=AOvVaw1-7rWgT885uRv-GNcJ-XcY&opi=89978449
White is the radio antenna so your looking in the right spot.
62Blazer
Midwest
Messed with it for a few minutes last night:
I did not have the radio antenna hooked up. Had trial hooked everything up to verify the plugs, but had to unhook them to put the bezel on. Did not rehook the antenna....works fine now.
Figured out how to do the presets.
Haven't figured out the details on calling via Bluetooth... when messing with it I thought I saw the little squiggly circle come up where you then say "call Joe Smith" or whatever. But that went away and couldn't duplicate it. Again, pushing the voice recognition or whatever you call it button on the steering wheel just mutes the stereo.
I did find the user's manual online and printed it. Though I will say it's not a very good English translation!
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Try holding down the voice recognition button for 3 seconds.
62Blazer
Midwest
I did get it figured out. Had to go into the settings of the new head unit and change one of the settings. Basically some type of operating system....you go in and they give a whole list of different options. In one of the videos they mentioned needing one system (like maybe ZTLink....or whatever the name was). I selected that and now it works fine. To be honest haven't driven the truck (not a daily driver) but in the driveway everything works. Maps, music apps, voice recognition calling. Still working on which button to push to switch screens and such.
glsander
