2013 Ram 1500 Key Fob Battery Help
AKJoe
Anchorage, AK
Hello! My battery finally died in the key fob for my 2013 Ram 1500. I opened the fob case and replaced the battery and closed it back up. When inserted into the ignition, it will start the truck normally, but the unlock/lock and autostart features won't work. Any ideas what I might have done wrong? I have confirmed the battery is inserted securely and oriented correctly.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Let the computer sort itself out
say 2 or 5 starts
My 2016 Spare FOB went squirrely 2 years ago
It was the Green Circuit Board that shorted out, causing my Ram's horn to start beeping, several times a minute
My new Spare FOB now in a plastic baggie, it is in parts & pieces
Atcer2018
Virginia
Also, if you have a second fob try the lock/unlock/remote start functions and see if they work. If the second fob works it’s most likely first fob is bad. If the second fob doesn’t work it could be a more complicated problem.
Marshall
Sk, Canada
2014 sport
take it apart again, and make sure its clean inside, look at the contact area on the rubber buttons and the contacts and the cck board.
Mine is push button start so it may be different then yours.
Don't wash the cck board, but you can wash the rest up, and dry it before putting back together Have a close look at the printed board, and make sure there are no cracks in the printed cck's
If there are, easy to fix if you know about soldering ( not plumping solder)
