herb625
My 7" display screen in the instrument cluster has been intermittingly flickering when on high brightness. Sometimes it is a constant flicker and other times it's not as bad. If I turn the dimmer down it stops, which is fine at night but during the day you have to turn the headlights on to do so and then the Uconnect screen is hard to see. I have taken it to the dealer and they did a reflash and it stopped for a day and then started again. I have had the battery and alternator tested and both came back good. I have double checked the fuses and even replaced the ones for the instrument cluster. Anyone have this issue before and know how to fix it??
