2014 1500 5.7 Hemi Ignition coil and spark plugs help ASAP
Hattan
Hi, I am new to this forum and owning a Ram. I found Rockauto to be more reasonably priced in comparison to O'Reilly's, Advance and etc. I would like to get recommend the correct OEM Coils and Spark plugs to order off Rockauto. I get confused reading other forums and I'd appreciate getting opinions from people more experienced than I am. I need to replace them asap before I get busy driving to school and work. Thank you!
H
Hattan
BadHemi2014
Greater Cincinnati area
^^What he said.
I will also add that your coils are probably fine unless you know there's a problem with them.
And an indispensable tool, makes the job WAY easier:
Gearwrench
H
Hattan
^^What he said.
Gearwrench
Yes the coils are good I just have one that went bad and I'm replacing it. I just ordered that tool last night lol.
H
Hattan
can someone please send me a link to a replacement for this from rock auto? I'm not sure what is it called exactly but I think it's a stabilizer bar end link at the front passenger side. Thank you.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Thank you for the quick and direct response. I got last questions for you, do I need to gap them or they are gapped correctly from the manufacturer? and do I need anti-seize or anything like that mentioned on other forums?
No anti seize recommended.......always check gap even though they are preset
crackerjack1957
crackerjack1957
Should also replace bushings in stabilizer bar but they make 2 different sizes
Put your vin# in the link below & check vehicle options that describe your Ram for correct bushings then copy & paste that number to Rockauto
H
Hattan
You should replace both sides........below is correct # if you have no lift......made for factory specs
I already placed my order with one stabilizer bar and trying to see if I can change it to two instead so far no luck. What happens if I do not change the bushings?
JustinRam1500
