2014 Ram 1500 5.7 Header fit
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Looking for some feedback on the ARH Stainless Longtubes 09-Up Ram 1500 5.7L Hemi 1 3/4" Primaries with Cats.
Any issues with clearance around steering & engine on the 2014 Ram 1500 with 6 speed transmission.
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
None at all. These are a direct fit header, and I've yet to see anyone with a set of ARH headers have clearance issues. I am even running their larger 1 7/8" headers on my truck, and they clear everything.
C
crackerjack1957
Thanks Matt, definitely buying from you, just looking for some feedback.
Also is the ceramic coating the best way to cut down heat in engine bay?
I used the thermal wrap many years ago, kind of a pain to wrap in the tight areas.
Need to find someone to coat also!
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
If you let your truck idle alot, then the coating is worth it. These trucks sit up high, and the engine bay is huge, so heat is not an issue once you are moving. I coated the set I'm running on our shop truck, but that was simply to keep them looking new...not so much because of heat. I had Jet Hot coat mine, but they were expensive (about $400 + shipping to coat just he headers. It was going to be another $150 + shipping to do the Y-pipe.)
