Shane R Tedhams
- Dec 22, 2018
- 20
- 8
- Location
- MI,US
- 2014
- 3.0L V6 Turbo Diesel
Alright here we go:
First off thanks to all you guys for your tutorials and troubleshooting guides. If it wasn't for you guys I would have ended up with a $3200 mechanic bill just for replacing a DEF tank. DEF fluid crystallized to integrated sensor in def tank. Removed filler hose from tank, siphoned def, put in distilled water, let it soak, siphoned out, put new def fluid in, started right up! I truly appreciate what you guys do here and have my respect. Now onto some other issues I have that I cant seem to find clarity on.
1. Any updates on getting a swapped 8.4 Ra4 to have full Uconnect access? I have a Canada built truck with the 8.4 ra4 but doesnt have Uconnect and want to know if I can swap out the unit with a US version and have full Uconnect access (I live in the US). I read something about the VIN has to be from the original truck or something. Thread was a couple months old so was hoping for an update.
2. If that doesnt work, is there an alternative to Uconnect? I just want to be able to remote start my vehicle from my phone with the OEM remote start installed.
3. If no reasonable solution comes to mind, is there something I can upgrade to that will work like a 10.4 Tesla style head unit that might possibly have a OEM remote start app? I really dont want to swap out the remote start.
4. Is there an alternative to WiTech 2.0? My keyless entry is intermittent, so is remote start, key fob, and the tpms message comes up on the cluster showing dashes where the psi number should be. The dealership attached a copy of "Customer satisfaction notification P15" which states that certain models need to have the rfh updated and show using WiTech 2.0. My dealership cant do it and says I have to take it to a Chrysler dealership but there are no guarantees that will fix the problem because my VIN or Manufacturing date doesnt fall within the specified models it effects. Why they attached I will never know because Chrysler and Chrysler dealership says it's not a tsb for my vin in dealerconnect. Check engine light isnt on either if that helps. I did replace batteries in key fob but no difference.
5. Are OEM backup cameras plug and play or are additional services required? My OEM installed backup camera became foggy which I figured was from condensation build up, so I bought another OEM backup camera to replace. My original part number was 56038978AG but I guess its replaced by the 56038978AL which is what I bought from Moparfactoryparts.com.
I have skimmed the forums for these answers and cant seem to find any clarity. If you have any further questions to help out feel free to ask. My response time should be no more than 10 minutes. I own a 2014 Ram 1500 Laramie 3.0L Turbo Ecodiesel 4wd. Any information would be very helpful. Even pointing me in the right direction or a link to another post where the question at hand has been answered. Thanks for taking your time to read this and sorry if it isnt in the right section!
