2014 Ram Longhorn: Constant air whooshing sound near drivers seat
Douglas Walouke
Madeira, Ohio
So my check engine light came on and I noticed, at about the same time, a constant air sound (like a leaking tire) around the drivers side of the cabin. Radio muted and climate system off. Anyone ever have a problem like this?
tfeni52355
Indian Land, SC
2016 Longhorn
5.7 Hemi, 4x4, Air Suspension
I have a 2016 Longhorn and the seat ventilation fan makes a whooshing noise when it runs. Very faint but noticeable. Not sure if this helps since you say the climate control is off but the seat ventilation fans might be controlled without the Heat or AC running.
Easy to check though. The switches are all there under the climate control.
RamCares
n/a
n/a
Hi @Douglas Walouke - If you are not able to determine a solution based on suggestions provided here and you decide to address this with your dealer, our team is always a private message away and more than happy to provide support.
Mark
RamCares
Dave2018
2018,Previous 1998
3.6L,Previous 5.9L
Brake booster leaking? It would sound more like a hiss that would change tone when you step on the brake pedal.
ChloeBrooks
