2015 1500 Wheel Well Access Cover Clamp
3M-TA3
Pacific Northwest
1997 & 2015
V10 & 5.7L Hemi
Apologies if already asked and solved, but I came up short after many searches. The wheel well access flap for the headlights in my truck uses a separate clamp, and when I pulled the headlights to change bulbs I put the clamps and fasteners in a plastic baggie and put them somewhere I could not possibly lose them, so of course I did.
My access flaps are not the one piece ones that just need a push fastener to hold them in place, Instead, it's a separate piece that hold the flap in place once it's attached to the wheel well with a fastener
Here the my fingers are holding the flap in place at the top and you can see the fastener hole at the bottom just below the end of the flap. I recall that the clamp (?) widens out where it covers the flap. I can probably fabricate something, though I no longer seem to have complete control of my hands, but does anybody know what this part is and where I can get it?
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
I used an industrial stapler to put mine back on. The plastic is very thin. The stapler worker great. I don't recall there being a device. I could very well be wrong..
Get better pic's that are a little more of a distance away,so we can see what you're referring to better.I can't see why you couldn't use a push pin or christmas tree pin though,that's what i used on both my 13 and 14 trucks.
3M-TA3
3M-TA3
Pacific Northwest
1997 & 2015
V10 & 5.7L Hemi
This might help. Confined to the house after some surgery, so using some pics from a YT video that I think will show the problem.1748798915772.png
My flap is like the one above (2014 model), but my flap (2015 model) does not have the tongue attached and is cut straight across. On mine there was a small bracket that replaced the flap that kept the flap closed. My guess was that they had problems with this style, then "fixed" it on mine, and finally went to the new style with a squared off flap that had the hole in the end of the flap.
Below is the 2014 style closed. It's a bit hard to see the flap outline so I added some red lines:
Basically the parts I misplaced replaced the tongue above. If I can't locate is I'm probably going to JB Weld some plastic to the flap and maybe reinforce it with some carbon fiber I have left over from another project. It's easier if I can find the part since my knees are shot so working in low places is less than fun.
This might help. Confined to the house after some surgery, so using some pics from a YT video that I think will show the problem.View attachment 567452
Still not seeing why you couldn't use a christmas tree or pop up pin to hold it in place
Rav3ncroft
Indiana
2018 RCSB Sport
It's sounds like the flap on his truck doesn't have the tab where he could use a christmas tree fastener. Can someone with a 2015 confirm? My 2018 has the tab and fastener design.
I think a drill would fix that,create a couple holes and use a push pin to hold it closed.Actually i'd heat an awl to cherry red and use it to melt a hole in the plastic,as it'll give you a stronger hole then a drilled hole.
3M-TA3
3M-TA3
Pacific Northwest
1997 & 2015
V10 & 5.7L Hemi
That's it exactly. The flap is cut square and does not have a hole. When I opened it there was a part that connected to the wheel well with a push fastener that clamped over the flap. That's the part I'm looking for.
3M-TA3
3M-TA3
Pacific Northwest
1997 & 2015
V10 & 5.7L Hemi
I don't think there is enough room in the overlapping material, but that's a good idea and will check it out. Thanks for the tip on melting the plastic as opposed to drilling! I'll use that somewhere even if it isn't here.
In plastic a melted hole is usually a stronger hole then a drilled hole is.Even if the hole only encompasses half the overlap,a christmas tree or push pin with a big head should grab the overlapped hole,especially if you do 2 holes,1 on each end of the flap.
3M-TA3
3M-TA3
Pacific Northwest
1997 & 2015
V10 & 5.7L Hemi
Some additional pictures (don't tell my surgeon I sneaked outside :) ). Thank all of you for your assistance so far!
Flap bottom is straight and there are no holes:
Opening without flap in place. The flap goes over the ridge just below the opening but no further, it falls well short of the hole.
You can see the end of the flap in this picture where I am holding it in place. the end of the flap is the dark line that goes to the side of my thumb then runs straight across above the hole. The missing part was placed over the flap and secured by a fastener in the hole.1748818118113.jpeg
3M-TA3
3M-TA3
Pacific Northwest
1997 & 2015
V10 & 5.7L Hemi
Also, it looks that there isn't enough overlap to allow for drilling a hole or two in the bottom of the flap because of the way the flap is molded to fit into the wheel well.
I've never went looking,but i wonder if you could hunt up the earlier flap with the tab.Check your local wreckers/market place etc,for somebody parting out an 09 to 14.
Rav3ncroft
Indiana
2018 RCSB Sport
Make your own tab out of plastic that covers the existing panel. Drill a hole in the small tab you made and push a christmas tree fastener through both holes.
ChloeBrooks
