2015 ECO Diesel Won't Stay Running
dlott
Nashville
3.0l ECO Diesel
Hi Folks! My first post on here.
I have a 2015 Ram Eco Diesel with about 145,000 miles on it. It has been running ok but needed some routine maintenance. I changed the oil following the procedure and put 10.5 qts T6 in it. I also changed the fuel filter and air filter.
When I started it it ran fine at first but when I put it in gear it slowly quit running. I then started it again and see warning about electronic throttle control problem. I ran it a few times and it finally started running ok again. This morning I went to start it and it starts then says low oil pressure then dies after a about 2 seconds. I pulled the codes and it has 17 codes. The main one I see is P0520.
It will not stay running. Any ideas?
