Pentastar oil fill mystery
Marshall
Sk, Canada
2014 sport
I have not done it, but I know some one that was pissed because he could not see the oil in his dark garage, so he drill a row of small holes in dipstick, the holes with oil in them will be in oil, empty hole is where the level is.
He said it works very well.
in the old days with steel rods, a real rough grind stone would make a ridge face and easy to see .
Mind you when the oils sits in old trucks for a year or 2, real easy to see level if any is on the dipinstick, same with diesels.
Had a Ford that oil was filled everytime gas was filled.
gfh77665
SE TX
2019 Classic
3.6 Pentastar
The dipstick in our 2013 Wrangler 3.6L looks like this and it is hard to read.
Are they still using this style in the 2021 Ram 3.6L ?
I would like to try the dipstick from our 2022 Cherokee 3.2L in it to see if it reads the same as it looks more like the dipstick in my Ram.
Insert clean, wait 10 sec., pull out, wipe dipstick sideways on clean cloth or paper towel, hold dipstick half inch away. . Look for the "wet" mark it leaves. Easy and accurate every time.
C
Cedar Plank
ON
3.6l0
Tried that approach also without success. The issue is that the top lip of the crosshatch area on the dipstick collects oil from the dipstick tube on the way down when inserting it . Always looks overfull as a result.
The only way I could get consistent readings is to insert JUST until the o-ring touches the dipstick tube and remove, and then roughly measure the distance between the oil mark and the full mark. It should be the same distance as the o-ring to the fully inserted point. Hope that makes sense.
mdc1990zr1
Conshohocken, PA
Can’t you file the ‘bump’ down?
Yardbird
Western NC
I think the larger round part is to help guide and keep the dipstick centered in the tube when inserting and removing. Just a guess.
I do know the stick is really hard to read when the oil is clean, and still not as easy to read as it could be when the oil needs changed.
